2000 Hyundai Elantra Shaky/sputtery/rough engine.
CHRISTINA SCHROYER
Engine Mechanical problem
2000 Hyundai Elantra 4 cyl Front Wheel Drive Automatic 110K miles
Started car on 9/11 and engine was extremely shaky and rough. Car seemed like it wanted to conk out. Very sputtery when I put it in gear to drive and the check engine light is on and flashing. I checked oil and transmission fluids; they are ok. I checked spark plug wires for connection and they are connected. I have gas. The car is much worse on an incline and not so great on a decline. It seems if I drive on a straight road it will at least go forward without so much sputtering. Fuel pump? fuel line? Tune up?????? Help!!! :) Thank you.
Sep 13, 2010 at 1:43 AM
  • 75,988 POSTS
Have the computer scanned for code/s-you have a problem within the engine management system that caused the CEL to turn on-This is your starting point of diagnosis,finding out what's going on.
Sep 13, 2010 at 10:39 AM
