2000 Hyundai Elantra oil pump
125,000 MILES • 4 CYL • 2WD • AUTOMATIC
SULLIWAR
how can i test oil pump oil pan is off
Apr 16, 2009 at 6:07 AM
  • 110,246 POSTS
Usually, the pump is checked with pan on, oil in it, and with a mechanical gauge that plugs into the oil sending unit. If you have it off, you will need to take it apart and determine if the gears are wiithin spec.
Apr 24, 2009 at 2:03 PM
