1997 Hyundai Elantra Won't start
PARROTHEAD10
  • 1997 HYUNDAI ELANTRA
Engine Mechanical problem
1997 Hyundai Elantra 4 cyl Front Wheel Drive
I have to depress the clutch in my Elantra to start it.
Now it will not start.
Sometimes I can depress the clutch several times and get it to start.
The battery is new and I have power from it.
Thanks.
Thursday, September 17th, 2009 AT 6:15 PM
Try a jumper on the clutch switch follow the clutch pedal arm till it meets the support bracket the switch is here disconnect the connector and jumper it and attempt to start the vehicle make sure you depress the clutch -
Friday, September 18th, 2009 AT 4:35 AM
