2003 Hyundai Accent white smoke
2003 HYUNDAI ACCENT
55,000 MILES • 4 CYL • FWD • AUTOMATIC
3BOYSMEN
white smoke when I first start my car lasts about 10 seconds
May 4, 2010 at 1:14 PM
BLUELIGHTNIN6
  • 16,542 POSTS
If white smoke is present, check to see if the proper amount of antifreeze is inside the radiator and the overflow bottle. Also check to see if antifreeze has contaminated the engine oil. You can look at the engine oil dipstick, or look at the under side of the engine oil filler cap. If the oil is contaminated with antifreeze, it will have the appearance of a chocolate milkshake. Do not start the engine if the oil is contaminated with antifreeze, as serious internal engine damage can result.
Sometimes a puff of white smoke from the exhaust at start up is simply water that has settled in the exhaust piping and gets burnt out.
May 4, 2010 at 1:21 PM
