Going down a hill (like coasting) and the car just quit. Doing starting u can hear it cranking but does not fire
Saturday, July 19th, 2008 AT 10:33 AM
KHLOW2008
MECHANIC
Hi Billy2423,
It is not possible for us to assist you with minimal info available.
You need to isolate the cause between mechanical, electrical and fuel.
At your mileage, if you had not replaced the timing belt, it could have given way. Check if the camshaft is turning when cranking.
Is there spark at the plugs?
Is the fuel pressurised at fuel rail?
SPONSORED LINKS
Sunday, July 20th, 2008 AT 11:16 AM
BILLY2423
MEMBER
It is the timeing belt. Friend who is a mech. Stop and took the cover alittle off to view it. Mech also suggest to change the pulley, water pump and all belts at the same time. Thanks for your answer.
