2001 Hyundai Accent Car engine won't fire
94,000 MILES • 4 CYL • FWD • MANUAL
CAT234
Drove the car to work fine this morning , although I have been having trouble starting it. It sounds like it wants to start but wont fire , what might cause this to happen.
Feb 20, 2008 at 6:50 PM
  • 75,988 POSTS
Get a carb cleaner and spray into the carb or the throttle body on an EFI. Did it start and die? If not disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel problem, check the fuel pressure to rule out the fuel pump and listen to the injector/s are they pulsing.
Fuel pump and Injector/s checks out-start checking the ignition system-power to coil, coil/s itself,distributor pick-up,control module, Cam and Crankshaft sensors.
If both fuel and spark is present-check the valve and ignition timing, this will lead you to problems with compression and valves opening and closing at the wrong time
Feb 20, 2008 at 8:32 PM
