There is a screw(t-30 torx) behind a plug at the inside door handle, and there is two screws behind the plate on the inside pull handle. Then you pull the door panel away from the door to release the clips.
SPONSORED LINKS
Saturday, September 4th, 2010 AT 1:24 PM
