2003 Hummer H2 front drive axle/bearing hub
2003 HUMMER H2
134,000 MILES • V8 • AWD • AUTOMATIC
MILLSGREEN
noise and vibration in the left front wheel. Can't tell if it is the drive axle or bearing hub. most prevelant when i am excellerating and at high speed. Going down hill or coasting the noise seems to deminish. i want to know so i can purchase the right part.
Thanks.
charles
Oct 25, 2009 at 2:48 PM
SERVICE WRITER
  • 9,123 POSTS
Does the noise change when veering to the left or right?
IS there any play in that wheel ?
Using push/pull movement check wheel off the ground at the 9 and 3 position and also at the 12 and 6 position.
By description, I am leaning toward axle aa the axle is under load when accelerating but the wheel should be checked to make sure all else is tight..
Oct 25, 2009 at 11:19 PM
