Axel wheel bearings
2005 HUMMER H2
110,000 MILES
AMY TWYMAN
My Hummer is driving fine not making any noises but I went and had a tire fixed and they told me that I had a problem because when it was up in the air my 2 front tires moved side to side is this a problem or is that okay for them to do that they said that my wheel bearings could be bad . Wouldn't I have some sign of a problem?
May 28, 2013 at 12:35 PM
CARADIODOC
  • 34,366 POSTS
Have the vehicle inspected at a second shop but don't taint their analysis by telling them what the first shop found. Let them find any problems on their own. Wheel bearings will get real noisy long before they get sloppy enough to feel by hand. If both front wheels were turning together and the engine was not running there is going to be excessive play in the steering gear allowing that to happen. If any other parts are worn you would have a lot of steering wander, especially at highway speeds.
GM does have a lot of trouble with front wheel bearings but they will cause a buzzing noise like an airplane engine when they're noisy, and on cars they commonly cause the anti-lock brake warning light to turn on.
May 28, 2013 at 5:56 PM
