2003 Hummer H2 replacing wheel bearing and hub assembly
2003 HUMMER H2
120,000 MILES • V8 • 4WD • AUTOMATIC
HANDYMANN316
I need to replace the left front wheel bearing and hub assembly. I can not get the Brake caliper mount off to take off the brake rotor. The 2 bolts that hold the caliper came out with no problems. The 2 bolts that hold the brake caliper mount willnot budge. I have tried breaker bars and impact tools. Do I need to heat the bolts to get them free? Are they reversed thread?
Mar 30, 2008 at 2:26 AM
DENNYP
  • 1,824 POSTS
Do not heat them! You will need a good impact gun or very large breaker bar. You could use a cheater pipe over the breaker bar for more leverage. Be sure you eat your wheaties!
Apr 5, 2008 at 1:06 AM
