2018 Ford Escape Cranks No Start
Check out the images (below). Let us know how it goes.
https://www.youtube.com/watch?v=lXLJbuAZ4CE
Check out the images (below). Please upload a video of the engine cranking over in your response of any problems so I can see if the engine is damaged or not.
Suggested Repair
The replacement fuel pump control module did not fix the no-start. Unplug the MAP and MAF sensors and crank again, since a failed sensor can prevent the fuel pump from being triggered. Also check for 12 volts on the white/brown and yellow/green pump feed wires at the tank harness, and determine whether the problem is fuel or spark.
Conversation Summary
A 2018 Ford Escape cranks strongly but will not start. The owner checked the fuel pump supply fuse and replaced the fuel pump control module after a jumper test made the pump run, but the no-start remained. The expert explained that the control module replaces a fuel pump relay, advised checking pump feed voltage, and recommended unplugging the MAP and MAF sensors to see whether a bad sensor is preventing the pump from being triggered while distinguishing a fuel problem from a spark problem.
