Horn, cruise, alarm, airbag/seatbelt indicator not working properly
2005 MERCURY SABLE
128,000 MILES • 3.5L • V6 • AUTOMATIC
HOLLYBTIERNEY
My horn, cruise and alarm do not work, the seat belt/airbag indicator flashes on and off. I have replaced the same O2 sensor two times and it keeps reading bad. Auto parts says it must be the wiring, I don't know what it causing these problems, they all malfunctioned at the same time. What could be the problem?
Sep 4, 2014 at 10:49 AM
CARADIODOC
  • 34,381 POSTS
The horn, cruise control, and air bag all have one thing in common. That's the clock spring. That's a wound-up ribbon cable in a plastic housing under the steering wheel. All three of those systems have circuits running through it.
By "reading bad", I assume you mean the Check Engine light is on and there was a diagnostic fault code related to the oxygen sensor. Those codes never say to replace parts or that they're bad. They only indicate the circuit or system that needs further diagnosis, or the unacceptable operating condition. When a sensor is referenced in a code, it is actually the cause of that code only about half of the time. You also have to look for broken or rubbed-through wires, stretched connector terminals, corroded splices, and things like that.
Sep 4, 2014 at 2:11 PM
HOLLYBTIERNEY
Thank you, I will have the mechanic look at those issues.
Sep 4, 2014 at 9:30 PM
TROYSTAPP42
My horn does not work.
Nov 11, 2020 at 12:07 PM
TROYSTAPP42
And cruise does not work either.
Nov 11, 2020 at 12:11 PM
CARADIODOC
  • 34,381 POSTS
