1999 Mercury Sable Horn Location
RAIRSYS
Electrical problem
1999 Mercury Sable 6 cyl Automatic 150000 miles
Where is the horn located so it can be replaced?
Dec 18, 2008 at 6:08 AM
ZACKMAN
  • 4,202 POSTS
Before replacing the horns, check the fuse and relay under the hood. Fuse is #19 15A inside the battery junction box - front center of engine compartment, behind the radiator, and the relay is inside relay box. Low pitch horn is at the right front of engine compartment, remove headlight for easier access. High pitch horn is at the opposite side.
Dec 18, 2008 at 10:33 AM
