Horn and cig lighter won't work
2002 SATURN SC2
140,000 MILES
SKELETON1284
Recently I noticed that my horn was not working and then went to change fuses and realized my cig lighter was also not working and that that fuse had been blown. I tried to replace the 20A fuse but it just sparked and instantly blew. Any suggestions
Jul 2, 2013 at 6:17 PM
FREEMBA
  • 1,152 POSTS
First the horn; did the horn work when you replaced its fuse? If not, try swapping the horn relay (located in the inderhood fuse box) with an identical one from the fuse box. If the horn now works, the relay is bad.
Now the lighter: Unplug the lighter and then install the 20a fuse.
If the fuse doesn't blow, then the light assembly is the problem (this is common on a lot of GM cars). Get another lighter assembly.
Let me know what you find.
Jul 2, 2013 at 6:49 PM
