1991 Honda Prelude Won't Start
No i cylinder postion sensor is alright because....???
You say fuel is ok to the fuel filter. Fuel because of gravity will seem like it has pressure at the fuel filter, but you want to know what the pressure is. I would get a reading from a fuel pressure gauge.
You say fuel is ok to the fuel filter. Fuel because of gravity will seem like it has pressure at the fuel filter, but you want to know what the pressure is. I would get a reading from a fuel pressure gauge.[/quote:215a588956]
You need to install a manual fuel pressure gauge to verify pressure.Is there a fuel press regulator? If it is on the fuel rail unhook the vacuum line to check for raw fuel in the vacuum line.When the press gauge is on the car watch how fast it goes up when the key is turned on, and see how fast it falls with the key off if it falls at all.
I've been away but now back to original problem. I haven't check fuel presssure yet( just purchased pressure tester( difficult to find). But I did check for leaks at the regulator ( no leaks). Also, I checked cylinder compression. It is as follows:
#1 115psi
#2 90psi
#3 90psi
#4 115psi
Looks a bit low. I was talking to an employee at the tool shop from where I purchaced the fuel pressure tester. He mentioned to me that the problem could possibly be a valve adjustment issue ( valves sticking). If so, what are the ramifications of misadjusted valves?
Thanks again for your time
Prelude2000
Just wanted to let you know, I found the problem. While checking on the valve adjustment, I noticed that the two cam shafts would not line up. Upon futher inspection, while spining the engine over I found 2 teeth missing in the Timing belt. So the mystery of the cylinder senor code on the onset of the problem is also solved. Thanks for trying to help. I hope your still around the next time I need some back up.
Prelude2000
Suggested Repair
Verify actual fuel pressure with a gauge rather than relying on fuel flow at the filter, and check the regulator vacuum line for raw fuel. Compression was somewhat low, so valve adjustment was considered, but the cause found was a timing belt with two missing teeth that prevented the camshafts from lining up. Replace the damaged timing belt and retime the cams.
Conversation Summary
A 1991 Honda Prelude with about 175,000 miles lost power, set codes 43 and 9, then would not start or rev above 1000 rpm. The owner confirmed spark, fuel flow, a working cylinder sensor, no regulator leak, and compression of about 90-115 psi. The expert advised measuring fuel pressure properly. The owner later found two missing timing-belt teeth and cams that would not line up, which explained the no-start and sensor code.
