1999 Honda Prelude Won't Start
SHOWNER
I have a 1999 Honda Prelude Type SH that has 116,000 miles on it. The problem is that the car won't start. The problem happened overnight. The instrument panel wouldn't even light up upon turning the key. No clicks, sounds, nothing. The car was able to jump start, but once you turn the key off and try the start the car again, same thing. Nothing. The battery, battery cable (positive), and the alternator have been replaced. Same result. Tried 2 other batteries but same problem. Fuses checked out fine. But the car can still be jump-started! The voltage across the battery terminals registers around 12.6V. When revved up, the voltage does not change. This was the case before and after the new alternator was installed. No one can figure out what the problem is so any other suggestions would be most helpful.
Sep 30, 2007 at 12:01 PM
  • 75,988 POSTS
Could be the ignition switch/neutral safety switch/starter relay or the starter itself.
Do this remove small wire at starter solenoid get a test light have someone turn key to start position do you have power?
Sep 30, 2007 at 5:10 PM
Suggested Repair
Check the ignition switch, neutral safety switch, starter relay, and starter. Remove the small wire at the starter solenoid and use a test light while someone turns the key to start to see if power is present.
Conversation Summary
A 1999 Honda Prelude Type SH with 116,000 miles suddenly would not crank or light the instrument panel, though it could be jump-started and then failed again after the key was turned off. The battery, positive cable, and alternator were replaced, fuses checked out, and battery voltage stayed about 12.6V without rising when revved. The expert suggested testing the ignition switch, neutral safety switch, starter relay, or starter by checking for power at the starter solenoid control wire in the start position.
