1993 Honda Prelude Won't Crank
REGGIEO
I have a 1993 Honda Prelude 1.8 engine, 150,000 miles, recently after driving the car I noticed that the brake lights remained on after I exited the vehicle. After looking on the floor board, I noticed several pieces of broken plastic, which appear to have come from the brake pedal sensor, which caused the switch to remain open. I immediately tried to start the car and it wouldn't turn over. The battery has plenty of power, everything lites up.......but starter doesn't activate. The car is a 5-speed.....I've checked the clutch fluid and fuses.....any Ideas...no problems prior to the brake lights staying on. Any help would be much appreciated.
Thanks!
Jun 29, 2007 at 11:05 AM
BRUCE HUNT
  • 3,754 POSTS
Replace the broken part and let us know. I think that will do it. Make sure that the clutch neutral switch is not affected as well. It will not start if that is broken too.
Jun 29, 2007 at 3:46 PM
Suggested Repair
Replace the broken brake pedal sensor and confirm the clutch neutral safety switch is not damaged, since a broken clutch switch can also prevent the starter from engaging.
Conversation Summary
The owner of a 1993 Honda Prelude said the brake lights stayed on after parking and found broken plastic from the brake pedal sensor. The car then would not crank even though the battery had power, the lights worked, and the clutch fluid and fuses had been checked. The expert advised replacing the broken part and verifying that the clutch neutral switch was not also damaged.
