1999 Honda Prelude Black Exhaust Smoke
ASPUNDE
  • 6 POSTS
My 1999 Prelude SH has black smoke coming out of the exhaust. Some of the people I talked to say its my Throttle Body, another person said its my computer or my piston rings are bad. And for some reason the gas mileage has also lowered. Can you help me Please
Thanks
Sep 16, 2006 at 5:38 PM
BRUCE HUNT
  • 3,754 POSTS
Black smoke is a state of having too much fuel to be burned by the engine. White is water, bluish is oil and black is carbon. Now, I of course look to the plugs to see what is happening. Are they getting deposited on with black? I would start with the timing. Is the timing correctly set?
Sep 18, 2006 at 12:31 AM
ASPUNDE
  • 6 POSTS
Well I checked the Spark plugs and they have black on the rim and the tip itself is a Red-ish brown. On the timing I don't really know how to check that.
Sep 18, 2006 at 6:27 AM
BRUCE HUNT
  • 3,754 POSTS
A timing light is needed and you need to disable the computer on the vehicle. Sounds complicated but it is rather simple to do. However, unless the basic timing of the vehicle is set correctly the fuel will not be injected at the proper time and it will be either too rich or too lean.
Sep 18, 2006 at 8:31 AM
ASPUNDE
  • 6 POSTS
Do you know the best timing light I can purchase and would that be all I would need to do in order to fix it.
Thanks
Sep 18, 2006 at 7:15 PM
BRUCE HUNT
  • 3,754 POSTS
No guarantee it will fix it. Timing lights are available from car parts places, ebay, pawnshops. There is nothing too special about them. I own a Craftsman.
Sep 25, 2006 at 2:47 AM
Suggested Repair
Black exhaust smoke indicates a rich mixture. Inspect the spark plugs, then check base ignition timing with a timing light after disabling the computer as required. Correct timing if it is off. Timing adjustment is not guaranteed to fix the smoke or poor mileage.
Conversation Summary
A 1999 Honda Prelude SH has black exhaust smoke and reduced fuel mileage. The owner was told it could be the throttle body, computer, or piston rings. The expert explained black smoke means too much fuel, white is water, and bluish is oil, and recommended checking the plugs and ignition timing. The plugs were black on the rim with a reddish-brown tip. The expert said a timing light is needed and the computer must be disabled to set base timing, but correcting timing may not fix the problem. Any ordinary timing light from a parts store is sufficient.
