1992 Honda Prelude Timing Belt Walks Off
GUNEFIGHTS4
i have a 92 prelude with a 2.3l si non vtec and i have done every thing i know to keep from walkin the timing belt off to one side every thing wher its at is new outher than the cams & crank i dont know munch more to do than to buy a nuther motor anything i can to do so it wont walk it off ?
Apr 19, 2007 at 10:48 AM
BRUCE HUNT
  • 3,754 POSTS
If you are referring to the car timing belt coming off on its own you need to do some serious measuring and checking of the alignment of the pulleys. Something is not correct and you are going to have to make some adjustments.
Apr 21, 2007 at 2:49 PM
Suggested Repair
Measure and check the alignment of the timing belt pulleys, then make the necessary adjustments so the belt does not walk off.
Conversation Summary
The owner of a 1992 Honda Prelude 2.3L SI non-VTEC says the timing belt walks off to one side despite replacing related parts other than the cams and crank, and is considering another engine. The expert advises carefully measuring and checking pulley alignment and making adjustments because something is not correct.
