1996 Honda Prelude Clutch Replacement
STRAYHONDA
Hey,
Am due to have my Clutch replaced and have been told that they have to remove the engine.. does this have to be done? am a little unsure about this..
Also on average how long would this take?
May 7, 2007 at 8:32 PM
BRUCE HUNT
  • 3,754 POSTS
They do NOT need to remove the engine. They will however need to support the engine and slightly lift it. They need to remove one of the motor mounts to replace the clutch. The one they remove is located on the tranny. They should not remove the engine.
May 8, 2007 at 7:00 AM
Suggested Repair
Do not remove the engine for the clutch job. Support the engine, lift it slightly, and remove the motor mount on the transmission so the clutch can be replaced. No labor-time estimate was given.
Conversation Summary
The owner of a 1996 Honda Prelude Type S asked whether clutch replacement requires engine removal and how long the job takes. The expert said the engine should not be removed; it only needs to be supported and slightly lifted after removing the motor mount on the transmission. No time estimate was provided.
