1993 Honda Prelude clutch replacement
126,000 MILES • 4 CYL • 2WD • MANUAL
BUZZNBECK
my clutch is about to give out and i woundered if you could tell me how to replace the clutch or direct me to a manuel which would give me a step by step. I have replaced clutches and r&r transmissions but not the type in the prelude/ thanks bruce
May 22, 2008 at 10:28 AM
KHLOW2008
  • 41,812 POSTS
Hi there
Since you have experience with rear wheel drive trans, this should not be much of a problem except for some variations.
You need to remove the driveshafts, rear trans mounting and shift cables and all the others are similar to other trans.
Don't forget to drain out the gear oil though.
May 25, 2008 at 12:55 AM
