1988 Honda Prelude Won't Restart Hot
SEALION
The prelude starts up, runs, and drives but the problem comes when shut off the engine after about 20-30 minutes (to go to the store or something) I am unable to start the engine for at least 30-60 minutes. When I go to turn the key I hear the engine try to start but it just cant quite make it. After serveral attemps I would smell raw gas. Any ideas? A classmate suggested it would be the fuel regulator.
May 5, 2006 at 10:57 AM
LOSONE
  • 1,616 POSTS
For us to be able to assist you, it is absolutely necessary for you to include the make, model, year and mileage of your car. Please include the tranny type and I will try and help you.
May 6, 2006 at 6:25 AM
SEALION
The car is a 88 Honda Prelude S 2.0 and the milage is about 230,000 miles. Transmission type is automatic. Thanks.
May 6, 2006 at 7:40 AM
LOSONE
  • 1,616 POSTS
You are smelling gas because you have flooded the cylinders with fuel. I suspect your problem is the EFI relay. It is located in the upper left side of the dash--way up. It is a dealer only item. I would also remove the plugs and repaece them with new ones as tey are gas fouled and that errodes the spark efficency.
May 6, 2006 at 8:27 AM
Suggested Repair
The raw-fuel smell indicates flooded cylinders. Suspect the EFI relay (upper left side of the dash; dealer-only part) and replace the gas-fouled spark plugs, which can weaken spark.
Conversation Summary
A 1988 Honda Prelude S 2.0 automatic with about 230,000 miles starts, runs, and drives, but after a 20-30 minute shutdown it will not restart for 30-60 minutes. It cranks without starting, and repeated attempts produce a raw-gas smell. A classmate suggested the fuel regulator. The expert said the smell means the cylinders are flooded, suspected the EFI relay high on the upper left dash (a dealer-only part), and advised replacing the gas-fouled spark plugs.
