1988 Honda Prelude Slow Crank
KFE77
  • 1988 HONDA PRELUDE
  • 4 CYL
  • FWD
  • 60,000 MILES
When I attempt to start my car, it is as if the battery is discharged. Even when I try to jump it, it still cranks very slowly. When I turn the key to start the car, the engine cranks very slow and weak. It does that a few times and finally engages. If it is very cold outside the car will not start, even with a boost. It does this when it is hot outside also.
I have also noticed that I am using a little more fuel than usual, but it could be from the cold weather.
I change the battery and it started a little better for about 2 days. I am not sure if it is the starter or starter solenoid or something else.
Thank you for your help.
Saturday, February 2nd, 2008 AT 1:34 PM
Have helper put key to start position and bang on the starter if it engages the engiine-starter has a problem. Get the starter current draw checked. The overrunning clutch could be slipping.
Saturday, February 2nd, 2008 AT 2:42 PM
KFE77
I had my helper (4 year old niece) put the key in the start position and banged on it. It fired up so I changed the starter and everything is perfect.
Thank you very much for your help and quick response.
I will be making my well deserved donation.
Monday, February 4th, 2008 AT 5:39 PM
I'm glad you got it all sorted out and thank you very much for the donation.
Monday, February 4th, 2008 AT 7:57 PM
