1991 Honda Prelude High Beams Go Out
NOVUS
I have a problem with my headlights on a 91 Prelude. Low beams work fine, but when switched to high, they go out. Is their a hi/low switch or relay I can replace to fix the problem.
Jun 8, 2006 at 4:47 AM
CODY-ODY
  • 57 POSTS
It might be as simple as having 2 lights burnt(those lights incorporate the 2 bulbs in one ) another thing is that if I remember correctly that model has flip up lights and if it does they often had broken wires right where the lights were(just follow the harness back from the lights)
Also start with the basics like the fuses.
Jun 20, 2006 at 11:11 AM
Suggested Repair
Check the dual-filament headlight bulbs and fuses, and inspect the wiring harness at the flip-up headlights for broken wires.
Conversation Summary
The owner of a 1991 Honda Prelude says the low beams work but the high beams go out, and asks whether a high/low switch or relay needs replacement. The expert suggests checking for burnt dual-filament bulbs, fuses, and broken wires in the harness near the flip-up headlights.
