the other thing is my DRL light is on all the time when i'm driving even though the light switch is off.
can someone send me in the right direction?
thank you so much
Have engine compression checked on all cylinders; similar readings help rule out ring or valve-seal oil consumption. Dark tailpipe residue and ground spots are likely water washing soot from a rich-running exhaust, possibly with slight oil burning, not oil dripping from the pipe. Thicker oil or additives are only temporary. Confirm daytime running lights in the owner's manual; they often stay on with the switch off.
The owner of a recently purchased 1997 Honda Prelude with a header and enlarged pistons reported a burning smell at stops, dark spots from the tailpipe after idling, rapid oil loss of nearly 4 litres over about 100 km, slightly longer starts, and a DRL indicator that stayed on. The expert explained that oil burned past pistons or valve seals would produce smoke rather than drip from the exhaust, and that warm condensation can wash black soot from a rich exhaust so it looks oily. A compression test was recommended; thicker oil was described as a short-term measure only. Daytime running lights commonly operate regardless of the light switch.
