One of the front headlights wont open automatically but it will close automatically, how much will it cost to fix this?
Oct 28, 2009 at 5:57 PM
KHLOW2008
✓Experienced Mechanic
Hi Chapman2233,
The headlight motor is faulty as one of the diodes in the motor circuit is bad. There are no recommended repair procedures except to replace the motor. If you can do repairs yourself, you can try replacing the diode. An ohmmeter with diode testing capabilities would be needed to test which diode is faulty.
