hard to shift gears on my prelude sh?
CHEECH6922
  • 7 POSTS
my 99 prelude sh with 94,000 miles. my car is hard to put in gear somtimes i checked the fluid and its full, bled the system, and still its hard to put in gear the clutch feels good. only at high rmps does it not want to let me put it in gear and some times when i pull it out of third to go in to fourth it feels like i pulled it out with out out pushing in the clutch. it also makes a weird buzz sound sometimes when its in gear and the clutch is pressed down. is it my ATTS or time for a new clutch?
Nov 1, 2006 at 9:03 AM
BRUCE HUNT
  • 3,754 POSTS
Just like the other post on the clutch right next to this one. Look at that one. But I would add that the next comment I would make after looking into both of my suggestions is to crack the engine and replace the clutch. Even if the clutch is good I would replace it all. That bearing that they used on the prelude must be very cheap. I hope you get a better quality one the second go round.
Nov 1, 2006 at 11:07 PM
