1999 Honda Prelude Clutch Shift Noise
CHEECH6922
  • 7 POSTS
my 99 prelude sh is having shifting problems. on the first gear it shifts ok but theres a wierd buzz noise when i clutch. then when i clutch to shift to second gear it doesnt goin or it goes in sort of rough. sometimes it makes a wierd zzzzzzzzcrk noise when it does go in gear. it does this with all the gears. is it time fora new clutch.
Nov 1, 2006 at 7:28 AM
BRUCE HUNT
  • 3,754 POSTS
Two things to try. First, put the car in first gear and start the car. Hold your foot on the brake and slowly let out the clutch. Note if the engine just flatout dies or if it hesitates like the clutch is slipping.
Secondly, I would look at the clutch fluid level. It sounds like it is low. If so, you need to look at whether it is the slave unit located by the tranny or the master unit where the fluid resevoir is located. It could be either one. Note wear any fluid could be leaking.
Nov 1, 2006 at 7:48 AM
COMADOG
  • 5 POSTS
I had the same prob. and it was the throw out bearing one day i forced it into gear and it busted
Nov 1, 2006 at 9:41 AM
Suggested Repair
Test clutch engagement by starting in first with the brake held and slowly releasing the clutch to see if the engine dies or the clutch slips. Check clutch fluid level and inspect the master cylinder and the slave cylinder at the transmission for leaks.
Conversation Summary
The owner of a 1999 Honda Prelude reported a buzz when using the clutch and rough or noisy shifts into second and other gears, and asked whether a new clutch was needed. The expert advised an engagement test and a clutch-fluid check, noting a possible leak at the master or slave cylinder. Another owner said a similar problem was a throw-out bearing that failed after a forced shift.
