1992 Honda Prelude No Start No Spark
GRINGOLOCO
I have a 92 Honda Prelude and it is not starting. I went to jump it one day because i barely used it, when I jumped it the device i was using blew and my battery died. I started it up with the battery dead and it turned on but when i bought a new battery and when i replaced it the car would no longer start. I think the car had recieved a jolt of 110 volts when the device blew. Now I dont know where the problem is. The starter and alternater are fine because I tested them. But one thing I noticed was that there was no sparks given from the spark plug cables. Could it be that my distributer blew or what could be the problem?
Feb 13, 2007 at 9:56 AM
  • 75,988 POSTS
Check for a blown igntion fuse before you get to the distributor. check the coil wire for spark. if you got it there inspect the rotor and cap it has to make out of there thru the wire to the plug.
Good Luck! Happy Valentines Day
Feb 13, 2007 at 8:22 PM
Suggested Repair
Check the ignition fuse before the distributor. Then check the coil wire for spark; if spark is present there, inspect the distributor rotor and cap.
Conversation Summary
The owner of a 1992 Honda Prelude says it will not start after a jump device failed and the battery was replaced. The starter and alternator tested fine, but there is no spark at the plug wires. The expert advises checking the ignition fuse, then spark at the coil wire, and inspecting the distributor cap and rotor if spark is present there.
