1988 Honda Prelude Not Charging
GRAVIE
the car is not charging, the alternator is getting power to it but none coming out. but when i had the alternator tested on a load tester it said it was putting out 17 volts, when i put it back on still nothing. any help or advice would be greatly appricated. thanks
Mar 17, 2006 at 2:12 PM
BRUCE HUNT
  • 3,754 POSTS
I would check the wiring and connections. You are getting no charge at the battery and yet the alternator seems to be doing its job. Wiring.
Mar 20, 2006 at 6:13 AM
Suggested Repair
Check the wiring and connections between the alternator and battery. The alternator tested at about 17 volts on a load tester but produces no charge when installed, so the fault is likely in the wiring or connections rather than the alternator.
Conversation Summary
The owner of a 1988 Honda Prelude with 180,000 miles reports the car is not charging. The alternator receives power but puts out nothing when installed, even though a load test showed about 17 volts. Expert Bruce Hunt advised checking the wiring and connections, since there is no charge at the battery while the alternator appears to be working.
