1986 Honda Prelude Intermittent charging problem
199,000 MILES • 4 CYL • FWD • MANUAL
JOHNNYDANGER
Well, a couple of weeks ago, my brake lights all went out. I replaced the switch at the brake pedal, and this did not fix the problem. However, my battery died, and when I jumped the car off, the brake lights functioned properly once again. Now, the battery will not charge most of the time. Sometimes, when I turn or drive on a very rough surface, the charging system will begin working, but it never lasts. Alternator, or some mystery loose connection?
Thank you in advance.
Jan 3, 2008 at 5:28 AM
FISHERMAN
  • 937 POSTS
[quote:b83d69af07="johnnydanger"]Electrical problem
1986 Honda Prelude 4 cyl Front Wheel Drive Manual 199000 miles
Thank you in advance.[/quote:b83d69af07]
Hello !!
When the alternator gets faulty the brake light come on, remove the alternator bench test it and replace if faulty.
Good Luck!
Jan 3, 2008 at 5:30 AM
