Hi jwarrenkcc,
Yes, the PGM-FI main relay is known to fail intermittently and when this happens, it might just start and stall and then becomes very difficult to start. If you let it sit and restart later, it might start immediately.
Remove the relay and check the circuit board for cracked solders. Resoldering the points often works.
SPONSORED LINKS
Tuesday, May 5th, 2009 AT 2:34 PM
