1995 Honda Prelude no start
NGET
  • 1995 HONDA PRELUDE
Engine Performance problem
1995 Honda Prelude 4 cyl Manual
i just want to know what wrong with my honda prelude 95 while im driving my engine jst starting to die and when im trying to start my engine again it wont start. And that day its raining and I have a cold air intake intalled on my car. And my question is do you guys have any idea what wrong with my car?
Wednesday, October 20th, 2010 AT 2:21 AM
Cranks but no start condition-do below to determine whether it's fuel or spark issue:
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, Do you hear the fuel pump come On when you turn key on? If not check fuel pump fuse and fuel pump relay if so, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
Wednesday, October 20th, 2010 AT 5:43 AM
