1995 Honda Prelude Vehicle will not start
JUMPIE999
  • 1995 HONDA PRELUDE
Electrical problem
1995 Honda Prelude 4 cyl Front Wheel Drive Manual
We have tried numerous things to make car start. Replaced coil and main fuel relay switch. Checked distributor cap and rotor button. Car sarted for a day now it wont start again. Anything else it could b?
Tuesday, March 16th, 2010 AT 8:40 AM
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
Tuesday, March 16th, 2010 AT 10:15 AM
