1993 Honda Prelude starting
RONYAR
  • 1993 HONDA PRELUDE
  • 4 CYL
  • 150,000 MILES
I have a Honda Prelude with 150,000 miles that intermittently would start but now completely will not start. Here is what I know. Normally the dash lights come on when trying to start but now they do not. Signal lights & wipers will not work but headlights do. The starter will work. No power to windows or sunroof. Previously (twice) messed with the trans. Shifter and it would start but no more. Any help would be greatly appreciated.
Friday, July 25th, 2008 AT 1:19 PM
Your gear position switch below the center console might not be making contact internally-jumper the black and white wire to the black and red, and see what happens then report back-
Friday, July 25th, 2008 AT 1:29 PM
RONYAR
Will do. I will let you know. Thanks.
Friday, July 25th, 2008 AT 1:36 PM
RONYAR
That did not do the trick. I have also checked the coil and there is no fire from there. Is there something common to the power windows not working and the car not starting?
Friday, July 25th, 2008 AT 2:07 PM
. Normally the dash lights come on when trying to start but now they do not. Lets go for the ignition switch test it out-also do you hear the fuel pump come On at run position?
Friday, July 25th, 2008 AT 2:13 PM
RONYAR
No Sir, I really could not hear the fuel pump.
Friday, July 25th, 2008 AT 2:26 PM
Get the ignition switch tested lets get it out of the way before we go to different areas-also the main relay
Friday, July 25th, 2008 AT 4:05 PM
