1993 Honda Prelude my car wont start
GWAPZDEOBOYNYC
  • 1993 HONDA PRELUDE
  • 6 CYL
  • 100 MILES
Hi when im driving my car it just stop and when I try to start it it dosent start I check the spark plug wire I take it of then I start it close to the engine theirs no spark on it
Thursday, July 30th, 2009 AT 10:41 AM
KHLOW2008
  • 41,814 POSTS
Hi gwapzdeoboynyc,
When sparks are not available, it could be a fault with the ignition switch, coil or control module or a broken timing belt.
Remove the distributor cap and crank engine and if rotor does not turn, the timing belt is broken.
If rotor turns, test for voltage at distributor connector Black/Yellow wire with ignition switch ON and while cranking. If voltage is available, the problem is either a faulty ignition coil or control module.
Monday, August 3rd, 2009 AT 5:37 PM
