HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Honda
Prelude
Drivetrain
Transmission
Clutch
Replace/Remove
1993 Honda Prelude clutch
HI ME
MEMBER
1993 HONDA PRELUDE
Transmission problem
1993 Honda Prelude Front Wheel Drive Manual
my clutch has no resistance and will no longer change gears
Monday, September 27th, 2010 AT 11:40 AM
KHLOW2008
MECHANIC
Hi hi me,
Have you checked the clutch fluid level in master cylinder?
I fluid level is low on none, top up the fluid and perform bleeding of the system.
Check for leakages at the master and slave cylinders and the hoses.
Monday, September 27th, 2010 AT 2:51 PM
Please
login
or
register
to post a reply.
Related Transmission Clutch Replace/Remove Content
1993 Honda Prelude Clutch Replacement
My Clutch Is About To Give Out And I Woundered If You Could Tell Me How To Replace The Clutch Or Direct Me To A Manuel Which Would Give Me A...
Asked by
buzznbeck
1 ANSWER
1993
HONDA PRELUDE
1998 Honda Prelude Clutch Change
Transmission Problem 1998 Honda Prelude 4 Cyl Front Wheel Drive Manual 120k+ Miles I Have A 98 Honda Prelude That I Love To Death....
Asked by
joshpriefer
1 ANSWER
1998
HONDA PRELUDE
89 Prelude..
Hi- What Should I Check As I Replace The Clutch On My '89si? There Is A Thumping Sound As I Come To A Stop And Thumping Other Times As Well...
Asked by
zippysidekick
1989
HONDA PRELUDE
1998 Honda Prelude Clutch Problems Shifting
My Car Recently Started To Get Difficult To Shift Between Gears. It Shifts Fine When Stopped But When I Try To Shift Into 2nd- 5th It Is...
Asked by
mbuck21
1998
HONDA PRELUDE
1997 Honda Prelude Gear Changing
Sometimes Cannot Get It In Gear And Changing Gear Is Very Rough. Slight Whining Noise When Changing Gear, Especially Changing Down. I Am...
Asked by
ericjack
1 ANSWER
1997
HONDA PRELUDE
VIEW MORE
Throwout Bearing - Secondary Cylinder Replacement
Pilot Bearing Replacement
Clutch Not Working
