Thanks
1997 Honda Passport Multiple OBD Codes
P0134 O2 sensor bank 1 sensor 1 no activity detected
P0135 O2 heater cucuit malfunction bank 1 sensor 1
P0305= Cylinder 5 misfire detected
P0341=Camshaft position cicuit range/perfomance
P0401= EGR flow insufficient.
Tune up check plug in #5, Remove egr and check for carbon in the valve and the port, clean the port with a piece of coathangar, push it right to the throttle plate. O2 sensor on the #1 spark plug side of the exhaust, the first one near the engine....clear those problems up and the CMP P0341 may clear...clear the codes after you change and fix erg...if the egr code comes back, you will need to replace the EGR Position sensor.
The MAF can be a dirty air filter, or the opposite, a vacuum leak too much unmetered air! Get a can of gomout and spray the inake manifold and vac hoses, if the idle changes you have found the leak!
Suggested Repair
Start with a tune-up and inspect the cylinder 5 spark plug. Remove the EGR valve, check for carbon in the valve and port, and clean the port through to the throttle plate. Inspect the bank 1 sensor 1 oxygen sensor on the number 1 spark plug side of the exhaust, nearest the engine. Clear the codes after repairs; if the EGR code returns, replace the EGR position sensor. For the MAF code, check for a dirty air filter or a vacuum leak by spraying intake and vacuum hoses; an idle change indicates the leak. Fixing these issues may also clear the camshaft position code.
Conversation Summary
The owner of a 1997 Honda Passport V6 with 90,000 miles scanned codes P0101, P0134, P0135, P0305, P0341, and P0401 and asked where to start. The expert identified them as MAF range/performance, bank 1 sensor 1 oxygen sensor no activity and heater circuit faults, cylinder 5 misfire, camshaft position circuit range/performance, and insufficient EGR flow. Recommended checks were the cylinder 5 plug, carbon in the EGR valve and port, the upstream oxygen sensor, and vacuum leaks or a dirty air filter, followed by clearing codes and replacing the EGR position sensor if the EGR code returns.
