1997 Honda Passport High HC and NOx
I have a 1997 Honda Passport (3.2L, V6 engine, 141,989 miles), and it has failed smog due to (very) high emissions, specifically "HC" and "NO" emissions. I had a diagnostic run on it, which identified Catalytic converter and O2 sensor problems, on the right side. I replaced the entire right side emission system (pipe, cat converter, O2 sensors), but the emissions reading came in even higher after that! I have replaced the air filter and added gas & oil treatments, apparently with no success. My "check engine" light is still lit as well (codes related to Cat, O2 sensor problems). Can anyone help?!!
Aug 22, 2007 at 1:06 PM
[quote:cf94e00f2c="scooper08"]I have a 1997 Honda Passport (3.2L, V6 engine, 141,989 miles), and it has failed smog due to (very) high emissions, specifically "HC" and "NO" emissions. I had a diagnostic run on it, which identified Catalytic converter and O2 sensor problems, on the right side. I replaced the entire right side emission system (pipe, cat converter, O2 sensors), but the emissions reading came in even higher after that! I have replaced the air filter and added gas & oil treatments, apparently with no success. My "check engine" light is still lit as well (codes related to Cat, O2 sensor problems). Can anyone help?!![/quote:cf94e00f2c]
We'll take this one @ a time
Check the EGR make sure its getting vacuum, also all passages clean of carbons.
Aug 22, 2007 at 8:25 PM
[quote:9d8ad93128="rasmataz"][quote:9d8ad93128="scooper08"]I have a 1997 Honda Passport (3.2L, V6 engine, 141,989 miles), and it has failed smog due to (very) high emissions, specifically "HC" and "NO" emissions. I had a diagnostic run on it, which identified Catalytic converter and O2 sensor problems, on the right side. I replaced the entire right side emission system (pipe, cat converter, O2 sensors), but the emissions reading came in even higher after that! I have replaced the air filter and added gas & oil treatments, apparently with no success. My "check engine" light is still lit as well (codes related to Cat, O2 sensor problems). Can anyone help?!![/quote:9d8ad93128]
O2 sensor/s is it OEM parts?
Check the EGR make sure its getting vacuum, also all passages clean of carbons[/quote:9d8ad93128]
If the EGR system is leaking or inoperative, it can cause driveability problems, including detonation (knocking or pinging when accelerating or under load), a rough idle, stalling, hard starting, elevated NOx emissions and even elevated hydrocarbon (HC) emissions in the exhaust.
Aug 22, 2007 at 8:39 PM
Suggested Repair
Check that the EGR valve receives vacuum and clean carbon from all EGR passages. Confirm the replacement oxygen sensors are OEM parts. A leaking or inoperative EGR system can raise both NOx and HC emissions.
Conversation Summary
The owner of a 1997 Honda Passport failed a smog test because of very high HC and NOx emissions. After replacing the right-side catalytic converter, exhaust pipe, and oxygen sensors, plus the air filter and fuel and oil treatments, emissions were higher and the check-engine light remained on with catalyst and oxygen-sensor codes. The expert advised checking EGR vacuum and cleaning carbon from the passages, asked whether the oxygen sensors were OEM, and explained that a leaking or inoperative EGR system can raise NOx and HC.
