1995 Honda Passport Engine Timing Fix
WESNINE62
How do you change the timing on a 1995 Passport V6 4wd without a distributer to turn?
Nov 16, 2007 at 3:54 PM
MERLIN2021
  • 17,250 POSTS
You don't! Timing is controlled by the PCM, not adjustable...
Nov 16, 2007 at 10:28 PM
Suggested Repair
Do not try to adjust ignition timing. On this Passport, timing is controlled by the PCM and is not adjustable.
Conversation Summary
The owner asked how to change timing on a 1995 Honda Passport V6 4WD that has no distributor to turn. The expert replied that timing is not adjustable and is controlled by the PCM.
