1997 Honda Passport Idle Revving
HONDAPASSPORT
My 97 Honda Passport is revving at about 3000 rpms when idle. It is an automatic transmission. It won't do this every time. It is kind of random. It will also rev up when I am slowing down, it seems like in between downshifts. I recently put in some fuel system cleaner. Would this cause any problems or would it be a transmission problem?
Mar 25, 2007 at 3:05 AM
BRUCE HUNT
  • 3,754 POSTS
Kind of a surging up and down of the engine speed?
Vacuum leak at tubing, leak in the intake manifold or intake manifold gasket, air in the cooling system, or a dirty air idle control valve are some of the possible causes.
Mar 26, 2007 at 3:33 AM
Suggested Repair
Check for a vacuum leak at the tubing, an intake manifold or gasket leak, air in the cooling system, and a dirty idle air control valve.
Conversation Summary
A 1997 Honda Passport automatic intermittently revs to about 3000 rpm at idle and also surges while slowing between downshifts. The owner recently used fuel system cleaner and asked whether that or the transmission was the cause. The expert described it as engine-speed surging and listed possible causes: vacuum leaks, an intake manifold or gasket leak, air in the cooling system, and a dirty idle air control valve.
