2001 Honda Passport car is stuck in park
159,530 MILES • 6 CYL • 4WD • AUTOMATIC
CODY STYLES
i can start my car but when i mash the brake pedal and try to take out of park, it wont come out of park! it's stuck in park. even tried jacking up the rear -end and rotating the wheels to try to take pressure off the tranie. didnt work. any suggestions? thanks
Nov 15, 2009 at 2:09 AM
KHLOW2008
  • 41,812 POSTS
Hi cody styles,
The shift interlock is malfunctioning causing the problem.
When brakes are depressed, are the brake lights coming on? If not, you either have a bad brake switch or blown fuse.
If brake lights are coming on, the interlock solenoid is not operating to release the shift lever.
Nov 24, 2009 at 12:47 AM
