1999 Honda Passport
1999HONDA
Engine Mechanical problem
1999 Honda Passport 6 cyl Two Wheel Drive
1999 honda passport 3.2 camshaft on left head will not turn trying to pu in time
Oct 11, 2009 at 6:33 AM
KHLOW2008
  • 41,812 POSTS
Hi 1999honda,
If the timing has skipped time, lower the pistons by turning the crankshaft by 15 degrees before attempting to turn the camshafts. Always turn one at a time and keep valves at minumum lift to avoid the valves from clashing when turning the camshafts.
Return the poiston to TDC after getting the camshafts correctly aligned.
Oct 26, 2009 at 3:37 AM
