1995 Honda Passport Clutch Fluid
1995 HONDA PASSPORT
18,500 MILES • 6 CYL • 4WD • MANUAL
DEANNAANN
The clutch resevor is leaking fluid, it has been doing this for awhile now, but we have just been making sure that we watch the fluid level, now it will not hold any fluid for more that 2 to 3 hours. I was trying to find the slave cylinder, but can not find it. I was told that it should be by the passenger tire on the front end, but still could not see it. Could you tell me where it is and it this sounds like the slave cylinder or maybe the something else.
Nov 26, 2008 at 7:16 AM
  • 31,937 POSTS
HI there,
The slave cylinder is the small round cylinder on the front of the gear box, with one metal pipe attached, it will have a rubber boot on it as well, if this is not leaking it will be the master cylinder.
Mark (mhpautos)
Nov 26, 2008 at 7:26 AM
