1991 Dodge Ram 50 White Smoke
HONDA
STROHMSUSAN
I had my 1991 dodge Ram 50 with 100,000 miles serviced. New brakes, exhaust mufflerreplaced, tail pipe replaced, fuel filter replaced, spark plugs replaced. After paying $700.00 I drove off thinking everything was cool but 4 miles down the road the truck started running bad and huge clouds of white smoke were coming from underneath the truck and from the back and 1/4 of a tank of gas was burned in that short time, I drove it back to the shop and they said it was probably a fuel injector problem. There were no problems like this before they did the work on it. Any clues????? I am on a limited budget and not sure if I want to sink any more money into the truck and could someone at the shop done something wrong to cause this new problem???
Jul 25, 2006 at 8:41 AM
MIKEYBDMAN
  • 623 POSTS
[quote:e1e0894bbf="strohmsusan"]I had my 1991 dodge Ram 50 with 100,000 miles serviced. New brakes, exhaust mufflerreplaced, tail pipe replaced, fuel filter replaced, spark plugs replaced. After paying $700.00 I drove off thinking everything was cool but 4 miles down the road the truck started running bad and huge clouds of white smoke were coming from underneath the truck and from the back and 1/4 of a tank of gas was burned in that short time, I drove it back to the shop and they said it was probably a fuel injector problem. There were no problems like this before they did the work on it. Any clues????? I am on a limited budget and not sure if I want to sink any more money into the truck and could someone at the shop done something wrong to cause this new problem???[/quote:e1e0894bbf]
Did your service Engine soon light come on? If so, this will set a code in the computer as to what system is malfunctioning. If not, then it may be a fuel injector staying open. On the more serious side, it may be a blown head gasket or cracked head.
I would suggest checking the compression on each cylinder and seeing if you have a major problem. If that checks good, then you will need to try and figure out if you have a bad injector, or other problem.
Codes are nice, and make trouble shooting a breeze.
Good Luck.
Jul 25, 2006 at 9:44 AM
94BOWDEN
  • 33 POSTS
as far as the white smoke its a blown head gasket for sure. they didnt torque the head down. a good way to know for sure is to drain the oil and inspect it. check for antifreeze and the smell of gas.
Aug 3, 2006 at 3:43 AM
Suggested Repair
Check whether the service engine light is on and retrieve any stored codes. Perform a compression test on each cylinder to check for a blown head gasket or cracked head. If compression is good, investigate a fuel injector that may be staying open.
Conversation Summary
A 1991 Dodge Ram 50 began running poorly, producing heavy white smoke, and using a large amount of fuel shortly after brake, exhaust, fuel-filter, and spark-plug service. The shop suspected a fuel injector. The expert advised checking for diagnostic codes, testing cylinder compression for a head gasket or cracked head, and then investigating a stuck-open injector if compression is normal. Another comment asserted a blown head gasket without confirming it.
