Honda Low Oil No Visible Leak
HONDA
VISHEETAL
Hi
For the last few weeks I have been noticing that my engine oil pressure gets low, runs fine for a week after the re-filling. There are no visible oil leaks spots under the car. I get my oil change done at Jiffy Lubes and they suggested that I might need new rear main seal or oil pan gasket. They are not sure. I am surprised that there are no visble oil spots under the car or on the gaskets. Could it be that oil is being consumed by the engine. I could smell a litle oil today morning when I started the car. but I donot know if that could be due to a cold start. As the smell subsided lately and there is no visible smoke coming out.
Any pointers are welcome.
Regards
Vishal
Mar 27, 2006 at 2:28 AM
BRUCE HUNT
  • 3,754 POSTS
It is being burned by the engine. Have you pulled a plug and looked at it. It could be a little oily and probably black in color. It may just be one cylinder or more. You are probably heading towards an overhaul.
Apr 1, 2006 at 3:58 PM
Suggested Repair
Oil is being burned inside the engine rather than leaking externally. Pull the spark plugs and inspect them; oily, black deposits on one or more plugs support internal oil consumption. An engine overhaul is likely if that inspection confirms burning oil.
Conversation Summary
A Honda owner reports low oil pressure that returns for about a week after refill, with no visible leaks under the car or on the gaskets. A shop suggested a rear main seal or oil pan gasket but was unsure. A brief oil smell on a cold start faded and there was no visible smoke. The expert said the engine is burning the oil, advised pulling a spark plug to check for oily black deposits on one or more cylinders, and indicated an overhaul is likely.
