1995 Honda Odyssey Oil Leak Behind Filter
DAVIDNGUYEN
  • 7 POSTS
:( my honda odyssey 1995 when i turn on the engine, oil leak from behind oil fillter .Is it not from oil fillter gasket. What do i need to do?
Feb 13, 2006 at 10:27 AM
FISHERMAN
  • 937 POSTS
where exactly the oil its leaking from?
can you see if its a juction or an screw?
Feb 14, 2006 at 1:33 AM
DAVIDNGUYEN
  • 7 POSTS
[quote="fisherman"]where exactly the oil its leaking from?
can you see if its a juction or an screw?[/quote] :) thankyou i found the clue they have a gasket behine are oil coolling return,before oil filter :D
Feb 25, 2006 at 2:29 PM
BRUCE HUNT
  • 3,754 POSTS
If it leaks in the area of the filter and you possibly did the oil change, check to be sure that there is not a second or old gasket on the filter.
Mar 3, 2006 at 9:28 AM
Suggested Repair
Inspect the oil filter area for a second or leftover old gasket from a previous oil change. Also check the gasket at the oil cooler return just before the oil filter, which was identified as the leak point, and replace it if damaged.
Conversation Summary
A 1995 Honda Odyssey leaks oil from behind the oil filter when the engine is started. The owner located a gasket at the oil cooler return ahead of the filter. An expert advised checking that a second or old filter gasket was not left in place during an oil change.
