1995 Honda Odyssey Timing Belt Manual
DAVIDNGUYEN
  • 7 POSTS
where do i found a book repair.I need alingment timing belt :?: thankyou
Jul 19, 2006 at 3:04 PM
BRUCE HUNT
  • 3,754 POSTS
Hard to follow your sentences, but are you asking about a repair manual? If so, go to any parts store and they should either have one or can order it in quickly. Otherwise, check library or online. I assume you need both and alignment and a new timing belt. The align is best farmed out to the pros but the timing belt is a doable project with the manual by your side.
Jul 20, 2006 at 9:12 AM
DAVIDNGUYEN
  • 7 POSTS
[quote="Bruce Hunt"] thankyou i just order book at amazon, today :D
Jul 20, 2006 at 9:53 AM
Suggested Repair
Get a repair manual from a parts store, library, or online. Have the alignment done by a professional shop. The timing belt can be replaced as a DIY job with the manual as a guide.
Conversation Summary
The owner of a 1995 Honda Odyssey asked where to find a repair book for alignment and timing belt work. The expert recommended a parts-store, library, or online manual, suggested having alignment done professionally, and said the timing belt is doable with the manual. The owner then ordered a book online.
