1998 Isuzu Rodeo Front Wheel Grinding
HONDA
JOHNDJ88FAN
i have a 98 isuzu rodeo and the front pass. side wheel sounds terrible kinda of grinding noise, almost like im dragging something. I can push the 4wd button and this noise stops. I used to be able to push the 4wd button and move forward and then push it again to disengage and then back up and this would cure this noise for a while. Seems like the noise would come back when i hit a big bump. But now it will not stop making this noise unless the 4wd button is engaged. Thanks
Nov 14, 2006 at 5:21 AM
BRUCE HUNT
  • 3,754 POSTS
Sounds like the beginning of a bearing problem or an automatic lockout that is failing. Post to the right forum for better help from their moderator. However, I would check those items out.
Nov 15, 2006 at 12:35 AM
Suggested Repair
Inspect the front passenger wheel bearing and the automatic hub lockout. The grinding stops only with 4WD engaged and previously returned after bumps, which points to one of those parts failing.
Conversation Summary
The owner of a 1998 Isuzu Rodeo reports a grinding, dragging noise from the front passenger wheel that stops when 4WD is engaged. Cycling 4WD used to quiet it temporarily, and bumps brought the noise back; now it stops only in 4WD. The expert suggests a failing wheel bearing or automatic lockout and recommends checking those parts.
