1997 Isuzu Rodeo Lifter Noise
ISUZU
JCARLOS
I have a 1997 Isuzu rodeo,v6,24 valves,3.2 engine.
my plroblems is that always has a very hard noise, i think that there are the valves or the lifters. I try by doing an oil change but it was the same, the sound doesn´t change, and a mechanic says it wasn´t the lifters becuase he change them to a 1998 honda passport and the sound doesn´t go away.
Please what can I do?
Thanks.
Apr 17, 2006 at 5:25 PM
JOUGH626
  • 55 POSTS
It might not be lifters. It could be a similar sound, knocking or pinging. This could happen at all engine speeds if your EGR Valve is faulty. It's right on top of the motor, close to the fire wall. Only two bolts hold it on, so it should be an easy change. I hope this helps.
Jun 17, 2006 at 10:22 AM
BRICKLAIR
timing belt has a belt tensioner and tensioner adjuster, play between the two sounds like lifters ticking
Apr 4, 2007 at 4:50 PM
2CARPRO JACK
  • 11,533 POSTS
I have seen the belt tensioners fail on those and the belt slaps around like mad
Apr 5, 2007 at 1:16 AM
Suggested Repair
Check the EGR valve for a fault that can cause knocking or pinging, and inspect the timing belt tensioner and adjuster for play or failure that lets the belt slap and sound like lifter tick.
Conversation Summary
The owner of a 1997 Isuzu Rodeo 3.2 reports a hard ticking or knocking noise thought to be valves or lifters. An oil change and a lifter comparison test did not change the sound. Experts suggest a faulty EGR valve or a failing timing belt tensioner and adjuster.
